Orbi WiFi 7 RBE973
Reply
Harmony Hub Not Attaching to New Orbi RBR853
dcsaul
Hi. Just bought an Orbi AX6000 RBR853+2 satellites, to replace my Linksys Velop.  Everything has connected to the new network, EXCEPT my Harmony Hub.  The hub connected to the Velop fine, but it will not connect/pair with the Orbi.
I have tried:
1. turning it off/on
2. pressing the reset button and trying all 3 reset options
3. changing to a more powerful power cord
4. the manual connection option using bluetooth
5.  etc.... everything ever posted on the web for this  problem.
I cannot see it on my network, so it does no good to try the scan all IP addresses.
On my Orbi I just have the one primary network setup: no guest, IoT, etc.
Does ANYONE have an actual answer for this?  Thanks very much!
Message 1 of 7
Accepted Solutions
dcsaul
Re: Harmony Hub Not Attaching to New Orbi RBR853
SOLUTION: I did a factory reset on the hub and remote.  The process went smoothly!
Message 6 of 7
All Replies
quagmire1
Luminary
You've posted to the wrong forum. This forum is for Orbi Pro users, and is not very active.
The forum you want to post to is:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Message 2 of 7
Guru
Try disabling AX mode on the RBR under Basic Tab/Wireless settings and set CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
I have tried:
Message 3 of 7
dcsaul
Firmware Version
V4.6.3.16_2.0.51
Message 4 of 7
dcsaul
Neither suggested solution made any difference.  The hub is not showing on the network.
Message 5 of 7
dcsaul
Message 6 of 7
Guru
Good to hear. Glad it worked.
Enjoy.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1740 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
