Orbi WiFi 7 RBE973
Reply
How does the RBKE960 assign clients?
Tajee
I have devices that are 2-3 feet from the satellites and 75% of those devices are connecting to the main router which is downstairs and 100ft away. Why are they not grabbing onto the closest satellite?
Message 1 of 5
CrimpOn
Guru
Re: How does the RBKE960 assign clients?
Have these devices been powered off and back on since the Orbi network was activated?
Message 2 of 5
Tajee
Most likely no.
Message 3 of 5
CrimpOn
Guru
@Tajee wrote:
Most likely no.
What would be the harm in discovering what happens if they are?
Message 4 of 5
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 544 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
