- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI wifi not visible
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI wifi not visible
Try a different wifi device and Orbi app?
Try setting up the RBR and RBS with a wired PC or laptop connected to the RBR and web browser pointed to 192.168.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could try connecting the orbi to the pc but this does not follow the netgear instructions and I would not be fully confident on what settings I would need to be setting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would follow what is seen in the setup wizard that will help you out in regards as to what you'll be doing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
MODEL: Orbi RBR750
Maybe aI'm not explaining correctly, I will try explain again a bit clearer.
The Netgear App ORBI is the app recommended to download and follow the steps which takes you through the steps required to get connected. The App tells the user on you phone to connect to the ORBI wifi. The ORBI WIFI is not visible to any device in my house, as mentioned above , laptops or phones. So I cannot follow the netgear instructions since I have come to a stop. Using any other app will result in the same since none of my devices can see the wifi from the ORBI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting up the RBR and RBS with a wired PC or laptop connected to the RBR and web browser pointed to 192.168.1.1. See if you can set up the RBR here and give a new SSID name. See if this appears on your devices. If it doesn't, you'll need to get the system replaced as it would be faulty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have connected the ethernet connection to my PC and typed the IP 192.168.1.1 address into the web browser but it can't see that page message. Seems unusual that a brand new device costing so much money was not tested beforeit left the factory?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does orbilogin.com or .net appear on the page?
Possible the unit is faulty. Either contact NG support and ask about an RMA or if you have a return policy with where you got it, get in contact with them...
