- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi WiFi 6E (AXE) and (AXE) Frequently Asked Questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi WiFi 6 (AX) and (AXE) Frequently Asked Questions
When will Orbi support 6E?
Answer: Currently there is no release date for an Orbi WiFi 6E system, but you can find the latest information on Orbi at https://www.netgear.com/home/wifi/mesh/
Does the new Orbi WiFi 6 systems work with the older Orbi WiFi 5 systems?
Answer: Orbi WiFi 6 devices will work with any other Orbi WiFi 6 devices, but Orbi WiFi 6 units are not currently compatible with the older Orbi WiFi 5 units.
What is the maximum number of devices the new Orbi WiFi 6 supports?
Answer: Orbi WiFi 6 Mesh System can simultaneously support up to 254 clients and allows between 40 to 100 concurrent clients depending on the model.
Is there an outdoor satellite for Orbi WiFi 6?
Answer: Currently there is not an outdoor version of the Orbi WiFi 6.
What are the advantages of going with the Orbi WiFi 6 over current non-Orbi router?
Answer: There are a number of advantages that Orbi WiFi 6 offers over a standard router:
- Orbi has a larger WiFi coverage area when compared to a single router, and can be expanded by adding additional satellites.
- Orbi has a single WiFi name and password, instead of having different ones for the 2.4 GHz and 5 GHz bands.
- Orbi WiFi 6 can handle more concurrent client devices when compared to a single router.
- For devices such as cell phones and laptops that support WiFi 6, the battery charge will last longer on the devices while they are connect to the WiFi 6 network due to a new energy management system built into WiFi 6.
Does the Orbi WiFi 6 system work with any modems, or only specific ones?
Answer: The Orbi WiFi 6 system will work with any modem that has an Ethernet port for it to connect to.
Does Orbi WiFi 6 systems work in buildings with metal or concrete walls?
Answer: concrete and metal walls will drastically limit the range of the WiFi signals.
Do endpoints (satellites) need to be 802.11ax to take advantage of all the features?
Answer: To take advantage of all the 802.11ax features the satellites need to also support this. (So you would only use Orbi WiFi 6 satellites in an Orbi WiFi 6 network)
What parental controls does it support, or when will they be available?
Answer: Current the Orbi WiFi 6 does not have parental controls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Orbi Community,
You may have a lot of questions about our new Quad-Band WiFi 6E Orbi Mesh System.
Check out this YouTube video: Introducing the NETGEAR Orbi WiFi 6E Mesh System (RBKE963) | Tech Overview
Here are a list of articles to learn even more!
https://kb.netgear.com/000062798/What-is-WiFi-6E
https://kb.netgear.com/000062797/What-are-the-benefits-of-WiFi-6E
https://kb.netgear.com/000062799/What-is-the-difference-between-WiFi-6-and-WiFi-6E
https://kb.netgear.com/000064250/What-is-quad-band
https://kb.netgear.com/000064249/How-is-quad-band-different-from-tri-band
https://kb.netgear.com/000064251/Do-I-need-to-have-a-WiFi-6E-router-to-use-WiFi-6E-capable-products
https://kb.netgear.com/000064252/What-are-the-key-features-of-the-RBKE960-series
https://kb.netgear.com/000060424/What-is-WPA3-and-how-does-it-work-with-my-NETGEAR-AX-router
Please feel free to create a new topic to get any other questions related to Quad-Band Orbi WiFi 6E Mesh Systems answered.
~ NETGEAR Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WiFi 6E (AXE) and (AXE) Frequently Asked Questions
Compatibility across Orbi systems:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good article, information and resources on Orbi system satellites:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good KB on Multi-Gig ISP and Router support information for models that support MG features:
https://kb.netgear.com/000064991/What-options-do-I-have-when-setting-up-a-multi-gig-connection
