- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBKE963 Wired Satellite Connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a 3 story home (approx 4000 sq. ft.) with gigabit internet. I’ve just purchased the RBKE963 mesh kit, and I’m planning on installing the router on the ground floor near the modem and connecting it's 10Gbps port to the modem's 2.5Gbps WAN port. Since the 2 satellites will be on 2 other floors of the house, I was planning on using existing CAT6 cabling in the house to connect one satellite to the router's 2.5Gbps port and the other satellite to one of the router's 1Gbps Ethernet ports. My rational was that this hardwired setup might provide better backhaul throughput than using the 5GHz WiFi backhaul channel when the satellites are separated by the distances (& building materials) involved in my setup. Two questions:
1. Is this reasoning sound due to the distances involved?
2. Would this free up the 2nd 5GHz radios in the router & satellites for additional 5GHz connectivity/throughput, or is it always “reserved” for a backhaul channel even if the satellites are hardwired to the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBKE963 Wired Satellite Connections
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Just make sure distances are good and pretty far. As the system is farly powerful. Depending on side of home, you may need only one RBS to deploy. I have a 5000 sq ft home and mostly use 1 RBS thats wired. Though I can have two if I turn down the power from 100% to 50 or 25%
2. Would this free up the 2nd 5GHz radios in the router & satellites for additional 5GHz connectivity/throughput, or is it always “reserved” for a backhaul channel even if the satellites are hardwired to the router? Always reserved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm a fan of the hardwired backhaul. I've used both an still end up back using it.
I'd try both with the satellite and see how it works.
I actually purchased a renewed tp-link 2.5gig unmanaged 8 port switch for pretty cheap off amazon so I'd have the 2.5gig backhaul link.
works fantastic. Does it provide any better speeds than the wireless backhaul? Debatable as my internet speeds are just like yours. But its fun to play with.
And no, it doesn't free up the wireless backhaul. I wish it would 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
