Orbi WiFi 7 RBE973
Reply
RBR750 - DNS settings disabled in router settings
claudiut
Apprentice
Hello,
I'm trying to configure a pi-hole for my network, but in the DNS settings section the DNS option selected is "Get Automatically from ISP" and it's also disabled, not allowing me to change it (screenshot below). Does anyone know why this option is disabled and how to enable it?
Thanks!
Message 1 of 4
Mikey94025
Hero
Re: RBR750 - DNS settings disabled in router settings
Do you have Armor or Circle enabled (these take over DNS settings).  Is your Orbi running in AP mode vs Router mode (as AP you rely on the DNS settings in the router).
Or, related thread: https://community.netgear.com/t5/Orbi/Cannot-set-my-own-DNS-servers-if-I-choose-quot-Get-Dynamically...
Message 2 of 4
claudiut
Apprentice
Armor is disabled.
Orbi running in Router mode
Message 3 of 4
Guru
@claudiut wrote:
Hello,
Thanks!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 772 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
