Orbi WiFi 7 RBE973
Reply
AX6000 - Single iPhone won't save network password each time I return home
Kyle6279
I installed the RBK853 (AX6000) and replaced my current router - used the exact same network name and password. All devices in my home connected seamlessly except for my iPhone 12 Pro which I used to setup my Orbi app.
Every time I leave the house and come home the router wants me to enter my password to connect again. I have reset all network settings on my phone and connected again but I'm still having the same issue.
I'm getting very frustrated and I'm reluctant to change the network name or password because I have so many devices connected to it. I don't want to update them all if there's a simple fix that I can do.
Has anyone had this issue that can help me solve it? Thanks!
Message 1 of 9
Guru
Re: AX6000 - Single iPhone won't save network password each time I return home
Not ever with any NG router or my Orbi AX system with a iphone 12 max I have. iOS 14.4.1. WPA2 and AES only.
Are you using any special characters in the SSID name or password on the RBR?
Forget the SSID name profile on the iphone then reconnect.
I would refer to Apple support for additional help and information regarding there product. Sounds like a iphone problem if this is the only device having this problem.
Message 2 of 9
Mikey94025
Hero
How strange.  Please give us the details of your wifi security and your iPhone settings - Maybe we will notice something different:
  • Is your Orbi wifi security set to WPA2-PSK [AES]?
  • In the iPhone, after you connect (by entering your wifi password), in the Wi-Fi settings panel when you press the (i) icon next to your wireless network this is what I have (all default, I believe):
    • Auto-Join: Enabled
    • Private Address: Enabled
    • Low Data Mode: Disabled
    • Congfigure IP: Automatic
    • Configure DNS: Automatic
    • Configure Proxy: Off
  • In your iPhone Settings if you pull-down and search for "orbi" and then select the Orbi app do you see:
    • Local Network: Enabled
    • Background App Refresh: Enabled
    • Cellular data Enabled
Message 3 of 9
Kyle6279
Mikey, thanks for responding.
My WiFi security is set to WPA2-Personal, I don't see an option for WPA2-PSK [AES] on the Orbi app. That's the only difference I see from what you sent below. Everything else matches up.
Message 4 of 9
Guru
Use a web browser and a PC or laptop to log into the RBRs web page under Basic/Wireless settings.
Message 5 of 9
RafS
Apprentice
This is an IOS issue and not  Orbi related.  I have the same problem with my iPhone and iPad.  Forgetting the network and rejoing it, sometimes works and sometimes doesn't.  I have reported this to Apple since I'm in the beta ios firmware rollout and it was fixed for a while but it keeps coming back.
Message 6 of 9
Guru
Thanks for letting us know. Hopefully Apple will get this fixed.
Message 7 of 9
Kyle6279
Thanks guys! I’ll contact Apple
Message 8 of 9
Guru
Let us know how it turns out.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1083 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
