- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mail issues through Orbi RBR850 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the most frustrating issue.
Around March, my Email began to play up. On and off during the day, my apple mail
Client would stop sending and receiving email. If I plugged into the US Internet router directly, there is no issue. Now, the confusing part is I can get Gmail and Apple mail just fine. But, none of the email addresses from my own IMAP servers and domains.
I get a message that mail cannot connect to server and a possible SSL Issue. Then at some point during the day, it might switch on for a while, then off. It’s random and really frustrating.
Any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mail issues through Orbi RBR850 Router
Try posting this issue on the ORBI (AX) forum. This forum is for the original ORBI not the WiFi 6 version. However, just to give you a possible solution, look at your current firmware version. If your currently installed firmware version is too far out of date you could have an "old" SSL certificate. I would definitely check with the experts on the ORBI (AX) forum first.
Good Luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a VPN activated? (either on individual machine or router?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Heathus wrote:
Hi there.
Any thoughts?
