Orbi WiFi 7 RBE973
Reply
RBR350 - Missing SSID on one device
F2026880
Tutor
Hi All,
I'm very new to the Orbi system but i've got a curious problem on my laptop. All of my devices(a mixture of WIFI and Wired) are all working but my laptop will not show the WIFI network the Orbi is transmitting(it's not in the list)
Orbi AX1800
Firmware(on RBR350) - V4.3.4.7_1.9.53_
 Sattelites - V4.3.4.7
Laptop
MSI 72MVR 7RFX Leopard Pro
Windows 10
I'm just in the process of making sure all of my drivers are up to date on the laptop. I have updated the WIFI and Network LAN drivers to the latest but this has made no difference to the SSID appearing. I'm just wondering if anyone has come across this issue?
Apart from this bug i'm loving the new Orbi system. Many thanks in advance.
Regards
Richard
Message 1 of 6
Accepted Solutions
Guru
Re: RBR350 - Missing SSID on one device
Mostly a driver problem or a out dated hardware problem...
Message 4 of 6
All Replies
Guru
CHeck to be sure that the wifi adapter drivers on you PC is updated first. Most cases this is the cause of out dated drivers...
Message 2 of 6
F2026880
Tutor
I have updated the WiFi to the latest drivers but no difference.  I'll go through the rest of the drivers to see if it makes any difference.
Is this a common problem.
Message 3 of 6
Guru
Message 4 of 6
F2026880
Tutor
Thanks for the assistance. I did donwload the latest network drivers from the MSI website(and installed) but it didn't make a difference. However i right clicked the network adaptor within device manager and it updated and worked. All sorted now.
Just need to learn how to use this new system. I'm very impressed so far.
Regards
Richard
Message 5 of 6
Guru
Glad you got it working. Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 759 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
