Orbi WiFi 7 RBE973
Reply
RBR850-frequently issuing DNS error in browsers then refreshes and proceeds to applicable webpage
ssgtweasel
Guide
Noticing intermittant issues on several of my home PCs, when opening webrower and type in an URL, I'll get an DNS probe error for maybe 2secs then automatically will open the intended webpage
Happens regardless of hard wired or wifi
using suddenlink cable modem only
RBR50 and BRS50 using latest firmware
THis doesn't happenn every instance though
Using ISP DHCP settings - haven't change to 8.8.8.8 or 8.8.4.4 in either cable modem setting or PCs
I found a similiar post from 2020 however I would have thought this issue may have already been addressed
Not using circle however using netamor
Firmware Version
V3.2.17.12_1.4.14
Message 1 of 10
Guru
Re: RBR850-frequently issuing DNS error in browsers then refreshes and proceeds to applicable webpag
Message 2 of 10
ssgtweasel
Guide
Ok thanks but
It’s dated oct 2020 and not real resolution unless I missed it
I don’t enter to manually set google dns in each device
Message 3 of 10
Mikey94025
Hero
Unfortunately the issue still exists and not solved by the latest Orbi AX firmware for the subset of customers impacted by this bug.  Follow the main thread if you want to watch for any new progress.
Message 4 of 10
DNS_PROBE_FAIL
Luminary
Yes, this is a well documented issue with Netgear Orbi AX systems but they're not fixing it.
Message 5 of 10
ed-win
Guide
DNS issue (and not getting any response from Netgear that they are busy fixing it) was reason for me to return the Orbi RBK853 router.
Wifi coverage was fine, but having to use the Orbi only as Access Point combined with my old router feels not ok.
Message 6 of 10
Guru
Future reference, some more detailed information is here about it:
https://community.netgear.com/t5/Orbi-AX/Intermittent-DNS-Errors-and-WiFi-Issues/td-p/1950768/jump-t...
NG IS aware of the problem.
AP mode is only a short term solution until NG fixes this.
Good Luck
Message 7 of 10
ed-win
Guide
Furry,
Good to know NG seems to be aware of this problem, but during all contacts I had with the support employees they never admitted the problem exists and that NG is working on a solution.
I received more info about the fact that I only have 90 days of support then info about a possible solution. Why don't they tell that the problem is known and that it will be fixed in a future firmware version? Why is there no list of known issues on the (support) site or in the community forum?
Message 8 of 10
Guru
I agree, would be more transparent and helpful to users to have a known list if issues. I believe that most 1st level support doesn't have more details on the issues at hand. There only there to help solve problems. I presume they don't get any back ground information from deeper sources. NG doeesn't seem to communicate or follow some better practices. Been like this for a while. And with what all happened last year, things were delayed as well so fixes that are on the table, may show up later than expected.
NG is aware. Heres to hoping for something soon.
Message 9 of 10
ed-win
Guide
I solved my issues by buying three ASUS ZenWiFi AX (XT8). Work great and have a lot of configuration options I was missing in the Netgear Orbi. Will not be buying Netgear again.
Good luck to the rest of you still on the Orbi AX.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1648 views
  • 4 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
