- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Verizon GB Fios...expectations for Orbi WIFI speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello.
I have the latest firmware for my RBR850. My current Verizon fios plan is the 1 gig up/down plan. I am not using the provided G3100 router from FIOS. I have the ONT plugged directly into the RBR850. I tested speed through a direct LAN connection on the RBR from my laptop and the results were terrific. 910/910. Unfortunately, I cannot get my wireless speeds past 330, regardless of the device. I've used iPhone 11 (wifi6), ipad pro (wifi5), and various other WIFI 5 devices to run these tests. The Orbi app shows the devices connected on the 5Ghz chennel. I've been using Speedtest app and Fast (app) for testing. The highest speeds I can reach are just north of 300. These test are done with no satelite connected and me standing 5-8 feet from the RBR850. Testing further (30-40 feet) away lowers WIFI speeds to 200. Does this sound right? My expectations maybe off, but for the price (FIOS internet plus Orbi RBR850 series), I would think WIFI 6/5 should result in speeds north of 500?
I've read the speed posts about the preamble. thresholds, channels, interference, etc. and have been unable to alter the results. I'm wondering if I should reconnect the G3100 router and test speeds with the same devices/proximity.
I'd be curious to hear from anyone that uses Verizon fios/orbi ...... with or without the G3100. Thanks in advance for the assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Verizon GB Fios...expectations for Orbi WIFI speeds?
Most iphones and WiFi 5 devices will max out at around 400-500Mbps due to the antenna design, 2x2. Even my 12 Max gets around 400 to 500ish speeds. I have a Asus GT-AX11000 router that is 4x4 that I can use as a wireless client and it can get 900Mpbs speeds. Connection rate between the Orbi AX and the Asus is around 1800Mpbs as well. Something my 12 Max phone doesn't get.
