- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
System Crashed this morning (after Netgear released a firmware update for them also)
- Mark as New
- Bookmark
- Subscribe
- Permalink
After running solid for 30 days around, the RBE973s system crashed.
the RBR came back, BUT one satellite will not come online (or found by the RBR), the other satellite is stuck in optimizing. All is wired backhaul, even if the wire portion crashed it should be on wireless backhaul.
NO I am not home, But received lots of texts from those that are about all kinds of stuff not working.
I have auto update OFF, but noticed their is an update available on the RBR 970 , have no Idea what version firmware is on the RBS's now, but have a great hunch its related to the new firmware Netgear released today.
I will update my finding latter or tomorrow, whatever the problem it is ..... should have never happened to a $2,200 + system.
I ran my other brand router 6E ( not wifi7) for 8 months solid with only one downtime, when I decided to do a scheduled firmware update , then it still ran till I swapped it with the 970 system. JUST A MAJOR NOTE TO Netgear!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: System Crashed this morning (after Netgear released a firmware update for them also)
What FW version is this running?
NG is looking for this particular issue.
Can you get the debug web page data off the RBR and RBS? IP address/debug.htm
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi There,
Engineering Team here.
I will be messaging you directly.
Also for a quick fix. Reboot router and satellites. If satellites still have issues. Please try factory reset on satellites only and wait 10mins and they should come back up and running
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was running 9.10.0.2 when this happened this morning.
I tried to reboot the cable modem and RBR with no luck on getting the RBS’s running.
I finally got home and power cycled the RBS’s and both came back up.
I did the firmware update to the beta.
All went smooth , I did power cycle router and entire 970 system exactly as Furry recommended.
I noticed my soundbars took 5 minutes to connect after I power cycled them. Now I think all is working
I hope not but if it happens again I will try to get the logs
Unless you need the logs now?
Thank you all!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Monitor for now and keep us posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
Might update if you see this, if you haven't already:
