Orbi WiFi 7 RBE973
Reply
Firmware update
fORBId
Firmware update
I am running RBS50 with router and two satellites.
On the Advanced/Administration/Firmware Update page I could see that I am running V2.7.3.22 on all three devices, and that there were no new updates available. However, on the Orbi support section of the Netgear website, V2.7.4.24 is available. I downloaded it and successfully installed it on the router.
When I went to install it on the satellites, however, I got a message that the firmware is wrong for the devices.
I am a bit surprised at this - would have thought that all three should be at the same level.
Does anyone know if it is normal that router and satellite run different firmware levels?
Message 1 of 4
Accepted Solutions
fORBId
Re: Firmware update
Apologies - I had missed out on the fact that there are two different versions for router and satellite ... please ignore this thread 🙄
Message 2 of 4
All Replies
fORBId
Re: Firmware update
Message 2 of 4
Guru
Re: Firmware update
If you got it figured out, simply mark it solved.
Message 3 of 4
Guru
Re: Firmware update
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 821 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
