Orbi WiFi 7 RBE973
Reply
RBR50 router won’t connect to orbi satellite
adiodoro
Follower
My RBR50 can’t connect to my Orbi satellite. I’ve tried factory resetting, power cycling, unplugging from wall and plugging back in, but the router just won’t connect. The router is updated to the latest firmware, as is the satellite, but nothing seems to work. When I try to sync, both start to flash a white light , looking like they’ll connect , but my satellite ends up with a solid blue light and my router keeps blinking white before eventually turning solid pink, and my satellite’s light will turn off. This just started happening a couple hours ago, I had lost connection and when I started to try and reconnect it, it just wouldn’t do it. Help me please. Thanks.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: RBR50 router won’t connect to orbi satellite
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Message 2 of 3
CrimpOn
Guru
As this web site indicates, when the satellite ring light turns solid blue for two minutes, that means it has a "good" connection.  It is supposed to turn off completely after two minutes of blue:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
This indicates that the link between router and satellite is good, but the router is not connected to the internet as it should be.
I would try rebooting the modem and then rebooting the router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 529 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
