Orbi WiFi 7 RBE973
Reply
Can't get to GSS116E Switch after backhauling Google Nest Wifi Pro Setup
mjolnier70
I recently connected my Google Nest WiFi Plus setup via a backhaul wiring and everything seems to be working correctly.
However, I no longer have access to the GSS116E switch admin panel. It shows an IP address of 192.168.0.239, and when I click the "Admin Page" button on the NETGEAR Discovery Tool, I just get page not found.
I'd like to go in and make sure I've made the correct settings for the network just to be safe. Does anyone know of a way into the switch? The tool clearly sees it, maybe I just need to add something to the URL?
Thank you!
Message 1 of 2
Accepted Solutions
mjolnier70
Re: Can't get to GSS116E Switch after backhauling Google Nest Wifi Pro Setup
Nevermind, figured out that if you unplug the switch for a minute and plug it back in it gets a new IP address from the new network. Did another scan and found it and was able to get back in. Thanks!
Message 2 of 2
All Replies
mjolnier70
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 370 views
  • 0 kudos
  • 1 in conversation
Announcements
