- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS308E all VLAN, how to connect to GUI now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @LL,
I had an GS108E and GS308E in my Network. All ports are assigned to an VLAN. some ports are trunked.
The Switches had an static IP.
On the DHCP the Switches don't show up, but work correctly.
Now I want to change some ports, but how to connect to the GUI now?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connect to an untagged port don't work.
Connect to the trunked (tagged) port work like a charm 😉
Fixed
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS308E all VLAN, how to connect to GUI now?
These switches can't get configured (Web UI)over a trunk with tagged ports. The IP stack is very basic, it does listen just to untagged frames.
Give the https://www.netgear.com/support/product/netgear-switch-discovery-tool#download a try to discover the switch in case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fixed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: [Fixed] Re: GS308E all VLAN, how to connect to GUI now?
Believe what you want, the IP stack on these switches can never work when your sent tagged frames to it. To allow config access under all conditions, run the management network untagged.
