- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS316EP Traffic Management problem - Switch limits throughput after a time automatically
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi community,
my configuration is built of 2x GS316EP switches connected together using port 1.
One switch is placed in the cellar, one switch is placed in a room on the 1st floor.
The distance is approx 25m (cabling distance).
During normal operations the throughput is as expected, but after about 2 weeks the switch on the first floor limits the throughput automatically to approx. 10% of the throughput before.
QoS settings are port based with Broadcast filtering enabled.
Rate / Storm control is set to no limit.
Priority control is not in use, all ports have the same priority (medium).
The switches are both on the latest firmware version 1.0.3.7.
There are no CRC errors and all other diagnostic tests show that ports are OK and there is no loop.
I assume it is the switch on the first floor, because when I reboot this switch the throughput si back, but when I reboot the switch in the cellar nothing changes.
I have searched the documentation and the internet as well as the Netgear community site, but I have not found any information how to remediate this problem.
Anybody any idea?
many thanks
mic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS316EP Traffic Management problem - Switch limits throughput after a time automatically
Hello Mic,
The only thing coming into my mind is that the link between the two switches (or the link to the device you testing the speed with!) does re-renegotiate and fall back to Fast Ethernet, actively using just to of the four wire pairs.
System -> Management -> Port Status ... Linked Speed
-Kurt
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll have a look and see what happens if the problem occurs again.
At the moment it is still running at full throughput.
many thx
mic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good catch ...
Isolating the problem is always agood idea and something I try first.
I have already tried some troubleshooting, but I have not posted what I have tried - sorry for that, maybe I should have posted my troubleshooting steps with the first post.
I tried to keep a long story short otherwise the post would have been a very long letter.
I have two Laptops for "mobile" troubleshooting, that I can use.
One is a Mac the other one is Windows 10 based.
Both have Gigabit Ethernet.
Before the switch on the first floor turned out to be the problem bear, I tried the following:
1. Tried to do performance tests (both Laptops) with 2m cables with the switch located in the cellar
> full throughput
2. Tried the same with the switch on the 1st floor
> limited throughput
I tried different cables to rule out a faulty cable.
3. Reboot the cellar switch and re-test the switch on the first floor (Perf Test Number 2)
> nothing changed
4. Reboot the switch on the first floor and re-test the switch on the first floor (Perf Test Number 2)
> full throughput
I then tried to find a setting on the switch on the 1st floor that could trigger the behavior.
Since I couldn't find anything, I asked in the forum (initial post).
thx
mic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Much more interesting would be what the switch port status show on each switch Web UI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you mean this ... yes
This is true for all ports except the rpinter which is not able to do 1000m Full.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They are both connected with these options
So far it still works with full bandwidth.
I´m still waiting for the problem to occur again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far, the problem has not recurred.
Since this is a GS316EP, how do I get a switch log file from it?
many thanks
mic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing the like even exists on these classic Plus switches, which are built on an unmanaged core and a tiny 8051-class micro controller holding the very basic Web UI, and the code for the Netgear Switch Discovery Protocol acessible by the ProSAFE Plus Configuration Utility, pure legacy (!), available as v2.7.8 via older model downloads, like https://www.netgear.com/support/product/jgs524pe#download - requiring Windows systems, requiring a workable installation of Npcap (currrent, legacy API), and the switch configured to allow Switch Management Mode, Web browser and Plus Utility and File Transfer via Plus Utility (TFTP) enabled, too. And yes, this does indeed all work on recent Windows 11 64-bit installations in February 2024. Still no switch log, even for old hardcore engineers 8-)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @micliner,
My apologies as this model can't generate logs. Anyway, this is only being experienced on the switch from the first floor and not on the one from the cellar, right? Have you considered switching them to see if the same behavior is being experienced? I don't think there is something wrong with the switches though as the problem only happens every two weeks.
Kind regards,
