- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS716T - Fiber Module
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two new small offices (<10 devices each). Fiber between the two switches (< 500').
Purchased the GS716T.
The fiber is being terminated with ST connectors.
What fiber modules are suggested for the above? (Normally I would use a external fiber to ethernet converter. This project has not been normal...)
Thanks, always a great forum,
Darryl
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS716T - Fiber Module
Hi,
Absolutley industry standard using SFP modules for fiber links 8-)
The hard work first: You have to figure out what kind of fiber is in place.Markings and colouring does help.
Non-military Applications | Military Applications | Suggested Print Nomenclature | |
OM1 62.5/125µm Multimode | Orange | Slate | 62.5/125 |
OM2 50/125µm Multimode | Orange | Orange | 50/125 |
OM3 50/125 µm (850 nm Laser-Optimized) Multimode | Aqua | Undefined | 850 LO 50/125 |
OM4 50/125µm (850 nm Laser-Optimized) Multimode | Aqua/Violet | Undefined | 850 LO 50/125 |
100/140µm Multimode | Orange | Green | 100/140 |
OS1/OS2 Single Mode | Yellow | Yellow | SM/NZDS, SM |
Polarization Maintaining Single Mode | Blue | Undefined | Undefined |
Based on this, you can select single mode or multimode SFP module (Netgear's reference listing -> https://www.netgear.com/business/wired/switches/accessories ) - for SFP look for 1000BASE-SX AGM731F or 1000BASE-LX AGM732F and order the matching patch cables. An LC/PC connector is required on the SFP module end.
Needless to say, beyond of the right fiber technology, the same frequency (colour) is required on both ends.
Netgear does not enforce exact vendor IDs (very different on the more expensive networking hardware makers!) and does commonly work with third party OEM modules.
