Orbi WiFi 7 RBE973
Reply
GS716T VLAN Configuration with Unifi
AbDhops
Hi All,
Apologies if this is already asked. But I searched and couldn’t found any solution.
I have GS716T, Fritz Box and Unifi AP.
Fritz box is DHCP server and providing 2 networks. 192.168.178.x (LAN1) and 192.168.179.x (LAN4). LAN 1 is connected to Port 16 and LAN 4 is connected to Port 15.
Unifi AP is having 2 networks, each having one WiFi with same name. Main (or default, where no possibility to add VLAN tag) and IOT which is having VLAN 100. Unifi AP is connected to Port 2 of GS716T.
Now, devices connected to Main get the proper IP addresses, and everything is fine. But devices connected to IoT, are not getting IP addresses.
Considering "U" and "T" (tagged and untagged), I have tried all possible 4 combinations. But no luck and issue is same.
Can some one help me to understand what the issue is.
Many Thanks to all.
Model: GS716T|16 ports gigabit smart switch
Message 1 of 2
Accepted Solutions
AbDhops
Re: GS716T VLAN Configuration with Unifi
SOLVED !
Issue was in PVID !!! Corrected it and worked like expected.
Message 2 of 2
All Replies
AbDhops
SOLVED !
Message 2 of 2
Discussion stats
  • 1 reply
  • 1142 views
  • 0 kudos
  • 1 in conversation
Announcements
