VoxPopuli
Dec 01, 2023Aspirant
MS510TX spontaneous rebooting
Hi all,
in my network I'm using a lot of Netgear (and other) switches, one of it is a
MS510TX with firmware 6.7.0.52/1.0.05.
It worked without issues for some time now, a few months ago I experienced a spontaneous reboot of the device. Since then the reboots seems to repeat every months. It seems that the time between the reboots decreased, today I've had two reboots on one day.
I haven't connected any additional clients or changed the configuration parameters of the clients or the switch.
The fan seems to be working as expected (no unusual sound) and the temperature stays at 46°C. The environment is dust free and the temperature is in a normal range (17-30°C).
Question: Is this a (known) issue with the firmware? Or is the switch aging that fast?
Thank you in advance!
Sort By
- VoxPopuliAspirant
A small typo, the switch temperature is at 36°C, not 46°C.
- VoxPopuliAspirant
I've tried to factory reset and restore the configuration and ran into (another?) bug. It wasn't possible to restore the configuration I've stored 5 minutes before from the same device/firmware before the factory reset. The error message stated that the following line is invalid:
snmp-server set rndImageInfoTable rndStackUnitNumber 1 rndImage2Description ""
