- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Internet Access
- Mark as New
- Bookmark
- Subscribe
- Permalink
No Internet Access
HI- im no expert here ! been using my switch for a while now for TV , IP Phone printer etc.etc. no problems - purchased new desktop PC and cannot access the Internet ? , i remove the cable which comes directly from the router into the PC and it connects great, put it back through the switch - and its gone.. any help would be appriciated. thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Internet Access
Welcome to the community! 🙂
With this setup: router--GS308T--newPC, kindly check if your new PC gets a valid IP address from the router. Make sure that the new PC is directly connected to the GS308T. If ever it gets a valid IP address, check if you can get replies when you ping the IP address of your router. Then if you are able to get replies from the IP address of the router, check if you can get replies when you ping the IP address of any website such as google.com.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi i have the ethernet connected directly to the pc - it states i have no IP address , but the internet works great. run it through the switch and the internet goes. New Cables & differnet ports have also been tried.
thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes i have Ping response from both my Router & Google
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you get replies when you ping the IP Address of your router and Google then you should have internet access on your new PC when directly connected to the GS308T.
Try to set Google DNS on your new PC such as 8.8.8.8 and 8.8.4.4. Check if it will let you access any website.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi nothing worked, ditched the Netgear Switch and bought a TP switch, works fantastic now
thanks
