- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Registration Key
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I want to ocnfigure this switch offline, however i don't get a full menu.
I can login with the default password but that is only limited functions.
I regsitered it and have a registration key, so next step seems easy.
However i don't find where to enter it?
I only get a login ask at when i surf to the IP. No option to login with registration key:
Solution is probably easy.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
In maintenance i didn't see the option, but i connected to internet and did a firmware update after which the key was asked.
This thread can be closed
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Registration Key
On the taged GS110TPP operating current firmware - when I have it right - there is the input field and two buttons [Submit] (to push the offline registration key) and [Login] (for the login password).
On the screenshot there is a GC510PP - never done offline registraion on the Insight [GC] switches. One would assume it would be similar. Ensure there is the current firmware in place - as of writing GC110 / GC110P / GC510P / GC510PP Firmware Version 1.0.5.29 . In case there is still only one button and the key can't be uploaded (double check there are no leading or trailing character like spaces or <cr><lf>) we need Netgear assistance or support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @JD33333
Thanks for choosing Netgear switch.
If you are managing the switch offline in switch local web-broswer based GUI, you can login to the switch GUI and go to "Maintenance" menu to enter the registration key.
After the switch is registered and the registration key is entered, you will be able to access the full switch GUI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
