- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Community,
is it possible to get the fiber-ports optics-infos via SNMP OID readout from a S350 Smart Switches (GS348T)?
If yes which OIDs / MIB they are?
For example I want to monitore this values in LibreNMS
*************** show fiber-ports optics-info all *************** Link Link Nominal Length Length Bit Possible 50um 62.5um Rate Speed Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance Supported Detected -------- ---------------- ------ ------ ---------------- ---------------- ------- ---- ---------------- ------------ --------- g49 FS 0 0 S2001345774 SFP-GE-BX 1300 1000BX10 Yes 1G *************** show fiber-ports optics all *************** Output Input Port Physical Port/ Temp Voltage Current Power Power TX LOS Fault Lane Number [C] [Volt] [mA] [dBm] [dBm] Fault Status ------ -------------- ---- ------- ------- ------- ------- ----- --- ------------- g49 g49-Lane1 47.4 3.270 17.7 -5.314 -40.000 No Yes Local Fault
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
All MIB are available along with the currenct firmware, e.g. for the GS348T here
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks I know. But which one is for the SFP transceiver statistics?
I already check some but did not find it.
May I need to spend more time into it...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Challenge support please, e.g. via https://my.netgear.com/ https://my.netgear.com/support/contact.aspx
No idea @JohnC_V or @ChristineT are still around and active here. @IphieChen @Iphie_C please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hallo @koeber,
willkommen in der NETGEAR-Community.
1.1. Welche Firmware-Version ist auf dem GS348T installiert?
1.2. Hast du die MIB «mib-2.my» angeschaut? Dort ist das Objekt «ifType» enthalten.
Mit freundlichen Grüßen
WojciechKrz
NETGEAR Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
The convenient SNMP Private MIBS - boxServicesFiberPortsOpticsTable .1.3.6.1.4.1.4526.10.43.1.16 table isn't implemented on the less expensive Smart Switch models.
This should be in fastpath_boxservices.my 8-)
-Kurt
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Wojciech_K
vielen Dank für deine Nachricht. ifType bringt aber nur
Name/OID: ifType.1; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.2; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.3; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.4; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.5; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.6; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.7; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.8; Value (Integer): ethernetCsmacd (6)
Name/OID: ifType.1000; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1001; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1002; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1003; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1004; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1005; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1006; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.1007; Value (Integer): ieee8023adLag (161)
Name/OID: ifType.10000; Value (Integer): other (1)
Firmware ist GS348Tv1_V1.0.0.43.
Viele Grüße
- Mark as New
- Bookmark
- Subscribe
- Permalink
@schumaku
In fastpath_boxservices.my I cant find any FiberPortsOpticsTable
Switch itself told me that they will support the following MIBs:
DIFFSERV-DSCP-TC The Textual Conventions defined in this module should be used whenever a Differentiated Services Code Point is used in a MIB.
DNS-SERVER-MIB The MIB module for entities implementing the server side of the Domain Name System (DNS) protocol.
HC-RMON-MIB The original version of this MIB, published as RFC3273.
IANA-ADDRESS-FAMILY-NUMBERS-MIB The MIB module defines the AddressFamilyNumbers textual convention.
IANAifType-MIB This MIB module defines the IANAifType Textual Convention
LAG-MIB The Link Aggregation module for managing IEEE 802.3ad
LLDP-EXT-MED-MIB The LLDP Management Information Base extension module for TIA-TR41.4 Media Endpoint Discovery information.
MAU-MIB Management information for 802.3 MAUs.
NETGEAR-BOXSERVICES-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR Box Services Feature.
NETGEAR-DHCPCLIENT-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR DHCP Client
NETGEAR-G8032-MIB The NETGEAR Private MIB for NETGEAR G8032
NETGEAR-INVENTORY-MIB Unit and Slot configuration.
NETGEAR-LOGGING-MIB This MIB provides objects to configure and display events logged on this system.
NETGEAR-MGMT-SECURITY-MIB The NETGEAR Private MIB for NETGEAR Mgmt Security
NETGEAR-QOS-ACL-MIB NETGEAR Flex QOS ACL
NETGEAR-QOS-COS-MIB NETGEAR Flex QOS COS
NETGEAR-QOS-MIB NETGEAR Flex QOS Support
NETGEAR-REF-MIB NETGEAR Reference
NETGEAR-SWITCHING-MIB NETGEAR Switching - Layer 2
NETGEAR-TIMEZONE-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR for system time, timezone and summer-time settings
RADIUS-AUTH-CLIENT-MIB RADIUS Authentication Client MIB
RFC 1493 - BRIDGE-MIB Definitions of Managed Objects for Bridges (dot1d)
RFC 2674 - P-BRIDGE-MIB The Bridge MIB Extension module for managing Priority and Multicast Filtering, defined by IEEE 802.1D-1998.
RFC 2737 - ENTITY-MIB Entity MIB (Version 2)
RFC 2863 - IF-MIB The Interfaces Group MIB using SMIv2
SMON-MIB The MIB module for managing remote monitoring device implementations for Switched Networks
SNMP-FRAMEWORK-MIB The SNMP Management Architecture MIB
SNMP-NOTIFICATION-MIB The Notification MIB Module
SNMP-USER-BASED-SM-MIB The management information definitions for the SNMP User-based Security Model.
SR-AGENT-INFO-MIB SNMP Research, Inc.
Looking futher through MIBs until I found it and will report here 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
as i wrote before:
Product management or engineering has not realized yet there are SFP ports on some bigger S350 models 8-(
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Wojciech_K können wir ein Feature Request machen, dies in einer neuen Firmware zu implementieren bitte.
Der GS348T kann ja prinzipiell via "show fiber-ports optics" die Transceiver auslesen 🤗
Vielen Dank!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any Updates on Fiber ports statistics via SNMP on S350 Smart Switches?
