- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SFP ports don't work after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
After upgrading the firmware from 1.0.4.16 to 1.0.5.12 my SFP ports no longer work. I am using RJ45 SFP adapters that were working perfectly prior to the update. I have also tried version 1.0.5.22 with the same results. Rolled back to 1.0.4.16 and they work. Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I switched to genuine Netgear adapers and everything is working fine
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SFP ports don't work after firmware update
Hm, more a GC510P or GC510PP? I would not write here without my GC510PP SFP ports in workable condition 8-)
The v1.0.5.12 (same for the GC110, GC110P, GC510P and GC510PP) is more than one year old - not sure why you upload such an dated version - as per the records Netgear pushed these and newer versions on Insight over the last 12 or 13 months. In local management, you could consider to upload GC110 / GC110P / GC510P / GC510PP Firmware Version 1.0.5.25 to the same Flash section (not to loose 1.0.4.16).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did try the latest 1.0.5.25. That's where I first noticed the problem. I went from 4.16 to 5.25. Down graded to 1.0.4.16 and they work, decided to start with .15 and see if it would work. It didn't so I didn't see a need to go back to .25 until I checked to see if this was an issue anyone else had.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem. My sfp modules are working with 1.0.4.16 but not with 1.0.5.27, extremely annoying.
After the upgrade the sfp link goes up and down allt the time. It kind of works for a second or two but then the link goes down. Happy for any suggestions on how to fix this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am now on the latest firmware and no change. I was using 3rd party adapters. I took a chance and bought a Netgear brand AGM734 and it is working. I have ordered a 2nd for the other port. Not sure why my generics stopped working after the upgrade though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FBCMoyock wrote:I was using 3rd party adapters. ... Not sure why my generics stopped working after the upgrade though.
Exact details please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thanks for the info. I'm using ubiquiti UF-RJ45-1G modules. It may then be that they are incompatible with later firmware than .4.16.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting, we're operating no-name Cisco-ID flashed 1G SFP RJ45 modules - absolutely flawless on 1.0.5.27.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is happen to me too , I have this version : 1.0.5.27 ( GC110 )
I have bought 10GTek SFP To RJ45 and This not working to me , How could I fix that ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@NetworkGB wrote:1.0.5.27 ( GC110 )
10GTek SFP To RJ45
Provide exact designation if this SFP module please, e.g. ASF-10G-T, ASF-GE-T, ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
10GTek SFP To RJ45
I have bought This :
https://www.amazon.com/dp/B01FRQJ1Y2
"1.25G SFP-T, 1000BASE-T Copper SFP, SFP to RJ45 SFP, Compatible with Netgear AGM734"
I would appreciate if you could help me please solve the problem.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue. Installed two QSFPTEK QT-SFP-M modules Netgear and the link goes up and down. Confirmed the laptop NIC works using one of the first 8 ports on the switch.
Any updates?
