Orbi WiFi 7 RBE973
Switch WITHOUT 802.3az
ijordison
I'm looking for a network switch which doesn't have 802.3az (Energy Eficient Ethernet) or where you can turn it off. Do the quoted models have the ability to turn it off? Or something with a similar form factor, where EEE can be turned off?
Model: GS108E|8 ports ProSafe Plus switch, GS308E|8 Port Gigabit Ethernet Smart Managed Plus Switch
Message 1 of 4
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Switch WITHOUT 802.3az
@ijordison,
Welcome to the community! 🙂
There is no option to enable/disable EEE (Energy Efficient Ethernet) on the GS108E and GS308E switches.
I suggest you the GS108Tv3 or the GS110TPv3 switches instead.  Both the GS108Tv3 and GS110TPv3 has an option to enable/disable EEE.  As reference, kindly read pages 93-94 of the GS108Tv3/GS110TPv3 user manual here on how to enable/disable EEE.
To know about the specifications of both the GS108Tv3 and GS110TPv3, kindly check the data sheet here
DaneA
NETGEAR Community Team
Message 2 of 4
All Replies
DaneA
@ijordison,
DaneA
Message 2 of 4
schumaku
Guru
For what reason exactly?
Message 3 of 4
ijordison
Dante.
It doesn't play nice with EEE.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3449 views
  • 0 kudos
  • 3 in conversation
Announcements
