× Get free training on Switching for AV over IP and receive AVIXA Credits. Sign up at NETGEAR.academy
Reply
AVB Switch losing all Crestron NVX transmission and needing to be rebooted
dacookster
Hey there, I have a small NVX system where a customer is reporting that all NVX stream transmission fails. A power cycle of the switch seems to restore proper function after all NVX products boot up again.
Symptoms include:
  • All decoding outputs to displays stop streaming/functioning
  • NVX products still respond to programming for control etc., only the streaming fails
Setup
  • Unit is configured using the Crestron NVX vlan profile applied to the control switch port of a Crestron processor, as well as all of the NVX product ports. Worked fine for about a week or so.
Just seeing if this has been reported or happened to anyone else.
Thanks!
Message 1 of 3
LaurentMa
NETGEAR Expert
Re: AVB Switch losing all Crestron NVX transmission and needing to be rebooted
Hi @dacookster ,
Sorry for this issue, and no - this is absolutely not normal.
Please send an email to ProAVDesign@netgear.com with the tech-support file out of the switch (AVUI Diagnostics\Support Diagnostics). You can also include a link to this post if you want, instead of repeating everything.
With the TS file, one of the ProAV Design SEs in your region / time zone will rapidly find the root cause and help you.
Without it, we cannot do anything else than guessing, but maybe also take a look at https://community.netgear.com/t5/Pro-AV-over-IP-Switches/M4250-40G8F-PoE-with-crestron-NVX-having-mu...
If this is your case, and the Management VLAN is down (Default VLAN 1), you should delete that Crestron Profile VLAN, and edit the Default Management VLAN 1 instead, applying the Crestron profile template to that VLAN 1.
Message 2 of 3
dacookster
Pretty sure I kept the default vlan but will have to return to site to be check. I will provide the support file like you suggested when I have a chance. Thanks for responding so quickly!
Message 3 of 3
Discussion stats
  • 2 replies
  • 816 views
  • 0 kudos
  • 2 in conversation
Announcements
AV over IP Switches by NETGEAR
