cresur
Jun 08, 2023Follower
M4250-10G2XF-PoE++ SFP port & AGM734 not working
Hello,
I have a few M4250-10G2XF-PoE++ switches deployed with AGM734 SFP modules installed in Port 11 & am not having any luck getting the ports to work. I get no connection with the device plugged into it, & in the AV UI the ports are grey & marked as "Blocked". I've tried swapping out the SFP modules & rebooting with no luck. I'm on the latest firmware. I don't see any way to change the configuration of these ports in either UI & they just appear to be inactive.
The device I'm trying to connect to that port is a Tascam CD-400U w/ an IF-E100 ethernet card installed.
Thanks in advance if anyone has any help!
1 Reply
Sort By
Just for the future reader (and probably not applicable to cresur here as he is using the port 11 when I read this correct).
Extended Datasheet M4250 Series for AV Line Managed Switches related to the AGM734 M4250-16XF (XSM4216F) - it does fits into M4250 SFP+ and SFP interfaces, and supports AGM734 on its ports 1 to 12 only.
Hard to say what does disable the port affected. Probably some Auto-DoS DanielZhang ?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
