× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
6.5.0-T338 Snapshot Management Wording
Guru
Just a small suggestion...
The wording on the current screen might be confusing.  Even when the "SMART SNAPSHOT Management" is off, the snapshots are still being managed by the custom settings.  The current screen will lead some people to the wrong impression that the settings underneath the control aren't being applied.
Though it would require a larger (or different style) control, using "Custom" instead of "OFF" would be more clear.
Message 1 of 2
Retired_Member
Not applicable
Re: 6.5.0-T338 Snapshot Management Wording
I couldn't agree more. Also, unless you're fiddling around with the GUI, there is no way to find this hidden feature. You have to turn off to see that there is more!
A switch Auto / Custom would be more suitable.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4274 views
  • 2 kudos
  • 2 in conversation
Announcements
