× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
6.7.5 RC1 opens rather than downloads
vandermerwe
Master
When I click on the link for the latest 6.7.5 RC1 firmware, the link seems to try to open the file rather than download it.  I get screens full of bizarre characters.  I have tried a different browser and both links, same result.
Right clicking the link and selecting "Save link as.."  works of course, but normally a simple click of the link will directly download.
Model: ReadyNAS-3100|ReadyNAS-3100
Message 1 of 7
Accepted Solutions
Skywalker
NETGEAR Expert
Re: 6.7.5 RC1 opens rather than downloads
Yes, we were required to add an anti-MIME-Sniffing header (X-Content-Type-Options: nosniff), which oddly made Chrome interpret application/octet-stream as plain text.  We added an explicit Content-Disposition header now, so it should be back to normal.
Message 7 of 7
All Replies
Guru
I didn't have that issue with Chrome.  Like the PC is configured to automatically open the file type.
Did you try a right-click and then do a "save as"
Message 2 of 7
vandermerwe
Master
Yes, as I mentioned, "Save link as..." works.
I am using chrome and edge and I haven't changed any download settings AFAIK.  Normally files download when links are clicked and I have checked by clicking links on the readynas download site - all the links when clicked lead to a download dialog box.  The link for 6.7.5 RC1 on the forum does not.
Odd.
Message 3 of 7
Jose00
Same for me (opens rather than downloads if I click the file, which I normally do). However Save As does behave as normal and allows to download (Chrome). Other files work fine so there is something different about this one. Cheers
Message 4 of 7
Guru
Oddly enough, it behaved properly for me about 10-12 hours ago, but is misbehaving now.
Message 5 of 7
TeknoJnky
Hero
I think this type of behavior is the result of incorrect MIME settings, either on the server or browser.
Most likely the server now that is affecting multiple users.
Message 6 of 7
Skywalker
NETGEAR Expert
Message 7 of 7
Discussion stats
  • 6 replies
  • 6087 views
  • 4 kudos
  • 5 in conversation
Announcements
