- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bugs...bugs...bugs !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Get only 17 MBs when copiying files on the nas.
When will negtear finally solve these issues ?
I spent more than 2000 euros (rnnas 516 and eda 500) and i shall have a system that works.
What to do ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Bugs...bugs...bugs !
calm down !!!
which firmware?
what hard drives? what raid level?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi matmar,
Which Firmware is your unit on? If Anti-Virus is disabled, is there any difference?
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Raid 6
6x Sandisk x110 256Gb in rnnas516 and wdefrx30 and 40 in eda 500
Antivirus off
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
why sandisk ssd?
check compatiblity list and select appropriate drives
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And issues that freeze the nas are an enormous ISSUE...
I report the issue since months....
- Mark as New
- Bookmark
- Subscribe
- Permalink
ssd supposed to have good read/write speed over spinning hard drives
in a nas this is not the case as i tested
apart from saving electricity and reduce vibration i cannot see any other benefits
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It'd be useful to share your test results (in its own thread).
The main speed benefit of SSD is that there is 0 seek time. So I'd expect there would be a significant speed gain if you are transferring directory information of large folder, or are copying a lot of small files.
I'd also expect the NAS to perform better under load - for instance, a scrub or a balance should have much less effect on end-user speed than you'd have with spinning disks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you post the contents of your btrfs.log?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
matmar when you download the logs zip file and extract the contents there is a btrfs.log file inside.
- Mark as New
- Bookmark
- Subscribe
- Permalink
btfrs logs sent
By the way what is the meaning of this :
WARNING: You are using an experimental version of the media stack.
Feb 26 21:31:22 nas-D5-D6-9E kernel: As the driver is backported to an older kernel, it doesn't offer
Feb 26 21:31:22 nas-D5-D6-9E kernel: enough quality for its usage in production.
Feb 26 21:31:22 nas-D5-D6-9E kernel: Use it with care.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
@matmar wrote:
btfrs logs sent
Thanks
Are you using your ReadyNAS in conjunction with some kind of TV card?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does you have the latest version of the DVBLink app installed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You will always see those messages from DVBLink, because they intentionally do exactly what the warning message describes -- building media drivers from other kernel versions, and installing them on the NAS kernel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This message does not apply to tv butler as it uses its own special user mode driver.
Oberon
What do you think ?
