× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RAIDiator-x86 4.2.28 [T6]
Skywalker
NETGEAR Expert
RAIDiator 4.2.28 is a minor update to the RAIDiator 4.2 series for the ReadyNAS Ultra 2/4/6 [Plus], Pro 2/4/6, NVX, Pro, 1500, 2100, 3100, 3200, and 4200.
To install a test firmware, download the release image from the link, go to the System/Update/Local tab in FrontView and upload the firmware image there. You will need to reboot the ReadyNAS once the image has been uploaded.
Bugs from this release should be posted in this forum with subject prefixed with the test release name, for example "Tx: this so and so does not appear to be working". Please be courteous and do not hijack a thread. If you have a different issue, open a new thread.
Test build and download link: 4.2.28-T6 (kernel sources)
Changes:
1. [T5] Fix NFS errors due to hash collisions on directories with many files.
2. [T5] Disable SSLv3 (POODLE vulnerability).
3. [T5] Fix 32-bit e2fsprogs divide by zero error (NVX, RN1500, RN2100v1)
4. [T5] Patch CVE-2015-0235 (GHOST).
5. [T6] Patch CVE-2015-0240.
Limitations:
1. IE 6 no longer supported. Please update to IE 7 or 8.
2. Volume expansion will not work beyond 16 TB. To support 16 TB or greater, you'll have to factory default with that capacity in place.
3. Snapshot resizing has been disabled in the release. We will re-enable this feature in a future update.
4. Maximum 2TB drive support on 3200/4200 v1 channels 5-12 due to LSI controller limitation.
Message 1 of 3
Skywalker
NETGEAR Expert
Re: RAIDiator-x86 4.2.28 [T5]
Updated with 4.2.28-T5.
Message 2 of 3
Skywalker
NETGEAR Expert
Re: RAIDiator-x86 4.2.28 [T6]
Updated with 4.2.28-T6.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7506 views
  • 0 kudos
  • 1 in conversation
Announcements
