sclubone's avatar
sclubone
Excess battery drain caused by RCloud iOS - Netgear should fix asap!!
After unexpected high battery drain on both my iPhone and iPad, it transpires that RCloud iOS will remain active in the background (for hours...) unless force-quit. The app shouldn't be in the iOS store in this state, and I hope Netgear issue an update asap.
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi sclubone,
    Can you provide more information about your iOS devices? What is the iOS version of your iPhone and iPad? Also, are you using the latest or up to date ReadyCLOUD iOS mobile app?
    Kind regards,
    BrianL
    NETGEAR Community Team
    • sclubone's avatar
      sclubone
      Hi, it's the latest iOS version on both iPhone and iPad, and the latest ReadyCLOUD mobile app (as all of these are automatically updated). i.e. 9.3.2 iOS, and 1.5.8 (134) for the app.
      I don't think the other thread is helpful as it relates to Android, but either way Netgear have serious problems if even the iOS app is broken in this serious way..
      • BrianL2's avatar
        BrianL2
        Hi sclubone,
        Well, it's not really the same but it's the same app running on a different platform or OS. I will check this with my colleagues and update this thread as soon as I get something.
        Kind regards,
        BrianL
  • BrianL2's avatar
    BrianL2
    Hi sclubone,
    I hope you can provide more information about your iOS devices. You may also want to check this similar thread about the issue that you posted.
    Kind regards,
    BrianL
  • No. What do you think it has to do with the app, when iOS reports battery drain by app in any case (with they netgear app identified)? Thanks
    • BrianL2's avatar
      BrianL2
      Hi JohnNulty & sclubone,
      Thanks for responding back. Let me forward this information to my colleagues to further investigate this issue that you've raised.
      Kind regards,
      BrianL
ProSupport for Business
