× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AP Mode R6220
mdherms
AP Mode R6220
I have an R6220 setup in AP mode connected to an R7000. Works fine. My question is does the CAT5 cable need to be connected all the time to the R6220 to reach back to the R7000 or can it be disconnected and connect back wirelessly? It doesn't really say in the manual if it needs to remain connected. I'd like to disconnect it and move the AP to a different part of the house but I can't run a CAT5 cable to that area. If it has to remain connected this product will not work as an AP for me. What would be a better choice as an AP?
Model: R6200v2|AC1200 Dual Band Gigabit Smart WiFi Router
Message 1 of 3
Accepted Solutions
mdherms
Re: AP Mode R6220
I will look for a "Wireless Network Extender"
Thank you!
Message 3 of 3
All Replies
antinode
Guru
Re: AP Mode R6220
> [...] It doesn't really say in the manual if it needs to remain
> connected. [...]
   Does it say that you can _disconnect_ it?  (Answer: No.)
   Something other than a wireless access point.  Pretty much by
definition, a WAP is wire-connected to the main router.
   There exist wireless network extenders which can use a wireless
connection to the main router.  There are also Powerline devices which
can use existing power wiring to emulate a real Ethernet cable.  Many
things are possible, but if you don't want to run a cable (or
equivalent), then you don't want a WAP.
   You might try a Web search for terms like, say:
Message 2 of 3
mdherms
Re: AP Mode R6220
Thank you!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1864 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
