× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Build a LAN with a WNDR3400v2
FredReed
I'm trying to make a wifi LAN with 4 devices for sharing. I don't need full time internet as it's a metered connection and I want to keep data usage down to a minimum. (It seems I need the internet connection for updating/setup for the router) All I have for internet connection is wireless hotspot on my S4.
"EVERYONE" claims I need "fulltime" internet or WAN to operate a LAN. I've seen C/NET articles that state LAN networks can be set up WITHOUT internet connection. C/NET is a well respected website with a wealth of good information about computer technology. What I can't find is HOW to set up the LAN I want.
The devices I want to share with are: HP TouchSmart IQ500 series desktop w/W10
                                                            Asus Eee PC 1005PEB netbook w/W7 Starter
                                                            Polaroid M10 2-1 tablet  w/Marshmallow
                                                            Galaxy SPH1337 S4 smartphone w/KitKat 4.4.2
It's a conundrum and challenge for me and would love for a knowledgeable tech person to help me figure this out. I'm willing to email off here and will post results to this if it's solved. I admit, it's bigger than the subject line.
OH, how do I change my email address here? Nothing listed in my profile or settings.
Message 1 of 58
Accepted Solutions
Guru
Re: Build a LAN with a WNDR3400v2
@FredReed wrote:
I forgot to mention this, I read about and watched a demonstration on "Pixiedust".
I'm not sure if it was a "brute force" attack over the internet or over the wifi signal.
Do you know? I'm sure there are newer ones since then too.
These attacks are to break into wifi.  Your router is not vulnerable to Pixie Dust.  I haven't seen anything specific on WPS brute force attacks.  But if you simply disable WPS on your router, you won't be vulnerable to this whole class of attacks.
Passphrases (and pins) can always be attacked by brute-force (which amounts to trying all possible passphrases).  There are ways to slow these attacks down - for instance, if the router is slow to respond after a couple of failed connection attempts, then the brute-force attack will take a lot longer.  Even a small delay is enough to make these attacks useless (because there are so many passphrases to try).
If you are worried about this particular threat, you can reduce the risk by turning your router's wifi off when you aren't using it, and by changing the passphrase from time to time.  In general, longer passphrases will be harder to discover by brute force guessing.
Message 48 of 58
All Replies
ElaineM
NETGEAR Employee Retired
Re: wndr3400v2 connect to internet with galaxy S4
Welcome to the community, @FredReed
The WNDR3400v2 cannot be used to bridge the Internet access to the rest of the devices you have.
You will need a physical modem to be connected to its WAN/Internet port.
What you're looking for is a router that has a bridge functionality and has a wireless client association.
Or you may want to enable the Tethering option on your S4.
Message 2 of 58
William10a
Master
As the post above saids the wndr3400 can not do any of functions the way you want but there is away to turn a wndr3400 into a wireless repeater I have never tried the setting my back up router by the way it is a wndr3400v1 that runs dd-wrt firmware that's the way I get it back and decided to leave that way it works for now.
If you would like information about the firmware version  I will post it for you but no guarantees if you try to reflash your router with dd-wrt you may have a brick.
Message 3 of 58
William10a
Master
Depending on how big of area you want to cover your own smart phone provider may hold the answer a personal hotspot network with a mobile hotspot box tied to your phone's account and with a data usage counter on the unit netgear has a few since I do not know your phone service provider is try seeing  if they are listed or check with your provider may be the best answer for you.
Message 4 of 58
FredReed
Thanks Elaine,
It's true, the bridge comes through a "modem' not the router and I can "tether" to my desktop through the S4.
The router is my "access point" through which my other devices can "share" with each other (but not the internet) after WPS.
That"s how I currently understand how it works. I'm looking for a LAN only but to be able to tether to my desktop when needed through the S4. Therein is my internet only "when I need it". My desktop is the only devce that has no internet access (no service at my apartment). The three others have wifi and are portable.
Do you see issues with my plans for a LAN using the router as an access point?
Message 5 of 58
FredReed
Thanks William10a,
I am downloading updates for my Polaroid M10 on wifi @ Walmart right now. Any of my portable devices I can do that. My desktop...
NOT so easy, no internet at my apartment. As for a hotspot at home, I can use the S4 "sparingly" as I'm limited to 6Gs on a family plan.
The plan is my sister's. Adding devices to it is not up to me so the S4 has to do for now. The S4 has a data usage counter and as it's an
AT&T dedicated smartphone, the counter is very accurate. (I do use the S4 for work too, email and Google maps. More bang for my AT&T buck)
I purchased a "heavy duty" power inverter for when I need my security service provider to update and clean my desktop. It will look weird sitting at a public wifi with a desktop updating but it's the only way I can afford to get around the large cost of in home internet.
I don't have the knowledge to access the internet on my own wihout paying someone as a "gatekeeper"! I wish we ALL could!
The project I am investigating is how to set up a LAN at home using my router as the "access point" to be able to "share" my files between my devices at home. I use wifi direct to print from my S4 but that only connects two devices for a short moment.
Message 6 of 58
William10a
Master
A wire stranger, an usb wifi adaptor and a usb extension cable equals a directional antenna and wifi with a good range works great in the country just like  a satellite dish focusing the wifi signal into point. Easy to video's on how to make on youtube. You could set  old computer to receive  wifi via a usb wifi adapter or wifi card and link the wndr 3400v2 router via lan card to the computer as a access point the computer would have assign the ip addresses. may be there is a easyer way but your phone would talk the computer and the computer would access the other devices if all works right. Just a different way of tring to make your idea work.
Message 7 of 58
FredReed
That sounds like a great idea. The wifi signals here are on the opposite side of my apartment building and, I'm in a basement apartment. (It couldn't be more wifi or OTA tv signal isolated!!!) How is the range of the setup you're describing?
Message 8 of 58
William10a
Master
The walls and floor stop most of the wifi it will have to be a mix of wired and wifi
Have you look into wifi repeaters or lan over power ?
Wifi may have a better chance cheaper then the Orbi system as you can place them where needed.
Lan over power needs to be on the same breaker panel and apartment buildings may have panels on each floor
A lan cable would work if the wifi repaers supported a backhaul network the max run would be 100meters or about 330 feet for lan cable.
Message 9 of 58
FredReed
AH,
It seems we have our thoughts crossed.
What I have is a small apartment. No need to repeat or extend the range of my router. The devices I have will be no more than 25' away.
What I don't have is Internet at my apartment.
The closest public wifi is close to a mile away.
A cardioid or beam antenna outside my building isn't allowed by the owner/management even if it did work at that distance. At this point, I'll work on connecting a LAN here to my devices and set the sharing for just here. Once that's up a working, I can investigate Internet service afterwards.
Thanks for.piqueing mind my mind. I used to talk "skip" on CB years ago so skip wifi sounds interesting.
Message 10 of 58
William10a
Master
@FredReed wrote:
AH,
 A wifi repeater with a backhaul lan port would allow the repeater to convert the wifi signal into a lan based signal that the router could understand.
As for the wifi depending on if you a unbroken sight of line to the public wifi and the gain of antenna you end up with a computer using a wifi usb adaptor could feed the Internet to the computer and it  via a lan port could feed the Internet signal out to your router via a lan cable if every works just right. The range and speed is hard to tell this crazy answer to free wifi it has many traps and pit falls but the repeater linked via a lan cable to your router should make devices into one lan one repeater should do the job. If you get this set up going please let me know. Please leave private networks alone and go by the ground rules of the public network.
Message 11 of 58
FredReed
Interesting concept. Didn't know there was a "backfeed". I wasn't planning on a.private simply because all of them are locked here. I've read about a method to "crack" wifi locks. Not sure if it's acceptable though. I'll keep you posted.
Message 12 of 58
William10a
Master
We are trying to reinvent the wheel netgear has a travel extender router here is the link http://www.netgear.com/home/products/networking/wifi-routers/PR2000.aspx#tab-techspecs this may be the answer a simple plug in devices with a internet lan port and just a lan port 10/100 mb.
Message 13 of 58
Guru
I agree, a WISP travel router would be able to bridge the connection from the WiFi hotspot, and could also allow local connections between the various devices (wifi or wired).  If there is more than one LAN device you'd add an inexpensive ethernet switch.  The devices should be able to connect with each other even if the S4 hotspot is off.
Message 14 of 58
FredReed
As it stands now, the devices are connected by wifi with no internet. Setting the sharing on each device is confusing as there are 2 Windows
(W7 starter, W10), and two Androids (KitKat 4.4.2,
Marshmallow 6) to set the sharing settings on.
Confusing because each one has a differant looking layout on screen. I'll worry about Internet later. Sharing settings are the important ones right now.
Message 15 of 58
William10a
Master
You would have public lan connecting to the internet of your phone acting as hotspot device allowing you keep track of your data usage for now, Later on you could make work with a wired lan or wired internet service.
Message 16 of 58
Guru
I'll start here, just to warn you that you likely won't be able to get internet working with this router and your hot spot.
The devices won't get internet, but they should still each be getting a 192.168.1.x local IP address when they connect to the router.
Before you graduate to sharing, you should first confirm that you have basic connectivity.
Starting with the windows systems - make sure the wifi connection is classified as "private' on the W10 system, and "home" on the W7.
Try opening a browser in one of the PCs, and entering http://192.168.1.1  Then log into the router's web page, and look for the attached device list. That should give you all four IP addresses (one for each connected device), and you should be able to ping all four from both PCs.
Run CMD on both the Win7 and Win10 machines to try this ping test for each IP address.  You enter
ping xxx.xxx.xxx.xxx
where the xxx.xxx.xxx.xxx is a placeholder for one of IP addresses..
Message 17 of 58
FredReed
Ok,
I 'm pretty sure I did set both W10 and W7 to private and home. I'll check the settings again.
The only time "public" setting is used is on any portable device when logged into a public wifi.
What I am confused about is, the "ping" test and "router login", aren't those two functions requiring the use of the internet?
Is there any non internet method for "logging into" the router? I don't have internet here.
As for the CMD, is this an "internet required" function also? Again, no internet here.
The next issue is the sharing settings. I set "what" I'm sharing on each Windows device but as for the two Androids, I'm even more clueless on "share" settings on these devices.
Side note: I entered one of the MAC addresses of the router into my Android phone tethering list but it doesn't show on the "allowed" devices" list.
It would have been nice to be able to "ping" and
login to the router that way. I presume that method doesn't work.
So, I believe there is basic connectivity as you described. I'll try either IE or Chrome for the "local" IP. Is the router's "web page" an "online" page or local LAN page where I'll see the list of connected devices and, is this where the "ping" test is done?
(Need to list my steps to learn and remember the basics AND the OS differances)
Message 18 of 58
Guru
Neither requires the use of the internet.
What you have set up right now is a private network that is isolated from the internet (which is a "network of networks" btw).  But you can still log into the router from your browser, and you should still be able to use ping to check connectivity on your private network.  Everything on the that network will be given an address (called an IP address) from the router.  That allows the router to forward the data to the right destination.  Netgear routers generally use 192.168.1.x addresses ("X" being a number between 1 and 254).  The router itself has a private IP address, and that should be 192.168.1.1.
Home networks are all private (as are most company networks), but usually they are not isolated from the internet. The router manages the private/public connections - similar to the way a human telephone operator would manage phone calls coming into a company (back in the phone extension days).  As far as the router is concerned, your outside internet line is simply broken.  It still will manage local connections (just like a company phone system would allow in-company phone calls even if the public phone lines are down).
So you can think of your devices on your private network as having a local extension that can't be directly dialed from outside, and which can't reach the outside unless the phone lines are up.  That's not 100% technically accurate, but using that framework will be helpful in understanding the basic concept.
Moving on to your S4 - it is also connected to your mobile data network.  So it will actually have two IP addresses - a public address from the mobile provider, and a private one from your router.   That is similar to a phone with two phone numbers.  Both work independently, and (in this case) there's no connection between the two "phone" lines.
If you open the web browser on either PC, and enter http://192.168.1.1 into the address bar, it should reach the router's web ui.  It will likely want you to go though the setup wizard (but that likely will get stuck because it will detect no internet).  If there's a way to exit the setup wizard (setting up manually) you should take it.  You'll then see all the router management screens, including seeing the list of the devices attached to your private network.
CMD.EXE is built into windows.  You can simply type CMD in the windows search bar (both for win7 and win10) and it will find it.  When you click on it, it will open a black window on the screen.  It is a command line interface, so you'll need to click on the window, and then type commands (like ping).  Windows will execute those commands and you'll see a response also in the CMD window. For instance,
The C:\>  is the CMD prompt.  That means that CMD is looking at the root of the "C" drive.  Yours should say something like C:/users/username>  The _ after the prompt is the an indicator that CMD is waiting for you to type something (on the prompt line).
I typed ping 10.0.0.1 at the prompt and then pressed enter. CMD ran the ping command which generated the response you see in the window.   Note my router is set up to use 10.0.0.x addresses (another range of private network addresses). 10.0.0.1 happens to be my own router.
Message 19 of 58
FredReed
StephenB,
You sir, have "hit the nail on the head" and drove it in all the way! (I've done some carpentry work) Your explanation has cleared up a HUGE portion of my questions and presumptions.
I was always under the presumption that there were LAN networks (business phone networks within a confined area as you described) long before any internet (outside "telephone network of networks". Remember Ma Bell?) even existed in our computerland we have now. I grew up during the changeover from dial telephones, wired to the wall in the front hallway and "party lines" in the neighborhood all the way to the current smartphone generation. From vacuum tube TVs that warmed up faster than many computers take to fully boot up! (Macintosh still makes some beautiful sounding vacuum tube powered audio equipment by the way. Check out the Best Buy satellite Macintosh offerings) OK, I've gone on a long enough tangent here.
I will do the things you suggested above and get back to the "share" settings questions asap.
So this is a preliminary THANK YOU StephenB.
I'll be back. I have sharing and security protocol questions as the equipment I have IS older "legacy" stuff to a large degree.
Message 20 of 58
FredReed
Well StephenB,
Found another issue. It seems that the W7 starter has the same IP as another device on the WLAN.
Could it be the W10 computer?
I printed out your last post, turned all 4 devices on and made sure all were connected. I entered the
http://192.168.1.1 as you recommended. The "Page can't be displayed" showed itself.
Next, I did a Windows Network Diagnostics and have a 6 page printout of that too.
The first issue found is, the internet connection is broken. The broadband is experiancing connectivity
issues.
I also found something called an "Inf date" on here of 7/16/2016. This was under the "Network adapter
Wi-Fi driver information.
The Connection status summary says the "connection started at:2017-2-28 and then the time of day.
The "Wireless Connectivity" diagnosis initialize status: Success... but,
it also says, "There may be a problem"
The "Wireless Network Adapter" diagnosis intitialize status: Success... but,
The Wi-Fi field here is crowded, as many as 17 other Wi-Fi routers are seen on the diagnostics printout.
Frankly, I don't know which way to go at this point. The http://192.168.1.1 wouldn't connect with my
router. The IP conflict with the W7 computer seems to be the first issue to be rectified???
Somehow I'ld like to get these guys to "shake hands".
Message 21 of 58
Guru
I agree that getting the basic connectivity right is the first step, and that requires making sure the IP addresses are being assigned, and that there are no conflicts, etc. And that you can reach the browser web ui.
@FredReed wrote:
Well StephenB,
Can you tell us that those two IP addresses are?  That might help.  Normally they should be assigned by the router, and I'd expect it to be assigning 192.168.1.2, 192.168.1.3, 192.168.1.4, and 192.168.1.5.  Certainly they should all be 192.168.1.x.
They are private addresses, it is safe to post them (and that's true even if the router had an ethernet connection).
Getting the IP addresses of the PCs might help us resolve that.  You should also be able to ping 192.168.1.1 using the steps above.
What browser are you using?
issues.
This is expected, since there is no internet connection.  I mentioned earlier that router would treat that like a broken connection.  The windows network diagnostics will also.
That's not unusual, especially in apartment/condo buildings.  That will hurt performance some, but your devices are all close to your router, and it should work pretty well.
I live in a free-standing house, and I still can see quite a few other routers when I scan.
Message 22 of 58
FredReed
What you state above regarding the acsending order of IP numbers, makes sense. i bring up my browser,
and this is the part where "Page can't be displayed" comes in. I don't know how to get past this point
This seems to be my misunderstanding.
StephenB wrote:  What browser are you using?
        I use the browser IE. The home page is set to Google.
        Chrome is on here just not set to default.
The "Page can't be displayed" is the browser's stopping place before finding the IP's for my computers.
(I am jockeying between wireless tethering on my S4 to Wi-Fi TO my S4 to write this. It's easier to type on my W10 than the S4 keypad!)
Message 23 of 58
FredReed
img001.jpgTHIS is my sticking point when I use the http://192.168.1.1:
Message 24 of 58
FredReed
OH BOY!!!
I just realized my thread here has the wrong title. It's misleading.
It should be:
"Build a LAN with a WNDR3400v2"
Is there any way I can change the title? LOL
WHAT was I thinking???
Message 25 of 58
Top Contributors
Discussion stats
  • 57 replies
  • 14819 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
