× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CLI "unknow command"
GautierS49
Tutor
Hello,
My compagnie has just provided me a NETGEAR GS108T and asked me to programmaticaly disable a specified port.
To do that, I need to do it manually first with CLI.
I have successfully connected to the SWITCH with telnet. According to a NETGEAR CLI user manual, I need to enter these following commands to disable a port :
#config
#interface 1/0/2
#shutdown and other commands
But when I write "#interface 1/0/2" to access to the 2nd port, the switch reply "unknow command"
What did I do wrong ? Probably this model of switch is not compatible with all CLI commands ?
Thank you,
Gautier
Model: GS108T|ProSafe 8 ports gigabit smart switch
Message 1 of 4
Accepted Solutions
Guru
Re: CLI "unknow command"
you'll have better luck in the switches forum instead of the general router forum.
https://community.netgear.com/t5/Switches/ct-p/business-switches
Message 2 of 4
All Replies
Guru
Message 2 of 4
GautierS49
Tutor
Will do thanks !
Message 3 of 4
Guru
Hope they've got some answers/help for you on there!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1245 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
