- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1150V &RAX80 & AX1800 howto monitor data per ip address
- Mark as New
- Bookmark
- Subscribe
- Permalink
howto monitor data per ip address! I need to figure out who/What is using a lot of data. Comcast is telling me we are using a lot more data and I need to figure out what devices / people are do it. Some routers have a page that shows this but I can not find it in my routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1150V &RAX80 & AX1800 howto monitor data per ip address
There isn't.
Netgear doesn't have a device specific data tracking feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK If Netgear does not have a solution. Does anyone have a idea how we can do this? I do not want to but if I have to I will look at other routers I know some do have that ability. I am hoping Netgear and or Armor can add that ability to track Data per ip.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can do it with 3rd party firmwares.
Snag a cheap (ish) router that supports ddwrt and go
CM1150V--->ddwrt router----->RAX80 in access point mode.
ddwrt has add ins that support individual monitoring but you'd need to do some modifications to do so. There's older routers that support ddwrt that you could pick up for pretty reasonable.
