× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't edit or create network folders on USB drive connected to router
Adoregon
Follower
I've attached a USB drive to the backside of my WNDR3400v3 router and followed the instructions to connect to it using readyshare.  I've renamed the share to \\Router\USB_Storage.  It appears in Windows Explorer as it should as a network "computer" and as a disk drive in the list of drives.  I've copied files and directories to it, edited them, saved them and deleted them.  It all works just fine, EXCEPT when I log into the router and try to edit the share name or create a new folder.  When I click on Edit or Create New Folder, the window refreshes with the same information.  It doesn't open the Edit/Create window shown in the user manual.
How do I go about editing/creating new folders?  Thanks!
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 2
Re: Can't edit or create network folders on USB drive connected to router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1383 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
