- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Configuring R6300 as an access point after firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I installed a firmware update this morning on my R6300 router (I am not sure how to tell if I have a v1 or v2 model):
Firmware Version
V1.0.2.80_1.0.59
After the update, there is no longer a Wireless AP option under the advanced setup menu. How do I configure my router as an access point with the new firmware?
Thanks,
George
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is it. The access point configuration is under "Use other operation mode" at the bottom of the screen shot.
Thanks,
George
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Configuring R6300 as an access point after firmware upgrade
On the bottom of the router you will find a label with a the model number if follow by a v2 or other version that the version of the model you have.
R6300 without a version number is a version 1, if you have say R6300v2 you have a R6300 version 2, and so on depening on how many versions for that model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the tip. Mine is a version 1.
I could still use some help with configuring it as an access point after the firmware update.
Thanks,
@William10a wrote:On the bottom of the router you will find a label with a the model number if follow by a v2 or other version that the version of the model you have.
George
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is answer from a few months ago https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/Is-AP-mode-in-R6300v1-possible/td-p/12...
The last poster tells how the R6300v1 in a access point mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks,
George
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'am happy that the community could help.
