× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Devices no longer can connect to network
jendavis
Devices (phones, iPads, smart TV) no longer can connect to home network.  The network is visible on the devices, but the password won't authenticate. I can get my laptop to access the network by plugging directly into the router. Everything looks normal on the router (i.e., all the correct lights are lit). Both modem (cable) and router have been unplugged and replugged. I downloaded the most recent firmware for the router. Still no success. Any ideas?
Model: WNR2000v2|Wireless-N 300 Router WNR2000v2|EOL
Message 1 of 3
Accepted Solutions
jendavis
Re: Devices no longer can connect to network
I just did a factory reset on the router, and the devices are able to connect again.
Message 2 of 3
All Replies
jendavis
Message 2 of 3
ElaineM
NETGEAR Employee Retired
Thank you for the update! Glad that it's working again after reset.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2687 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
