× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Enable Remote Access Fails - "Incorrect request format, try again."
Hacheta
Tutor
I no longer can login to my router using genie app remotely , the remote access is not Turing on anymore and it gives me “Enable Remote Access Fails - "Incorrect request format, try again." I updated the router to the latest software. Can you someone please help ?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
Re: Enable Remote Access Fails - "Incorrect request format, try again."
Is that the Android genie or the iThing genie? It might make a difference.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
If you do reset it, remember to enable remote access again. Indeed, check that it is still enabled before you reset. Maybe the firmware flash turned it off some how.
Message 3 of 3
All Replies
antinode
Guru
> [...] it gives me "Enable Remote Access Fails - "Incorrect request
> format, try again."
   Is that the whole message?
> [...] I updated the router to the latest software.
   An actual version number would be more informative than your opinion
of what's "latest" (today).  If the trouble began when you updated the
firmware, then you might want to try reverting to an older version.
Message 2 of 3
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 782 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
