× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Guest network ac1750 model R6300v2
taherte
Tutor
I don't really know what I am doing but I set up a guest network yesterday. I tested it today and found that when I connected to the guest netowrk, I was able to view files and folders on my PC's hard drive. This is how I have set up both the 2.4GHz and 5G profiles. What have I done wrong?
Message 1 of 6
Accepted Solutions
taherte
Tutor
Re: Guest network ac1750 model R6300v2
Problem solved. There actually was no problem except between my ears. Sorry for wasting everyone's time. Thanks for the quick replies.
Message 6 of 6
All Replies
Guru
What firmware version are you on?
Message 2 of 6
taherte
Tutor
Message 3 of 6
Guru
You could try updating the firmware. Not sure if it'll help but you can always try.
https://www.netgear.com/support/product/r6300v2#download
that router is pretty out of data. You might check into some 3rd party firmwards like dd-wrt or tomato for it.
They'll give it a few enhancements over stock.
Just be advised, there's always a chance of bricking a device when installing 3rd party firmware.
Message 4 of 6
schumaku
Guru
Start with the installation of R6300v2 Firmware Version 1.0.4.52 and check this Guest WLAN again following the mandatory reboot.
Message 5 of 6
taherte
Tutor
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 612 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
