× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How do I change the GUI password on my WNDR3700v4 router?
Spica
Hello, I would like to change the GUI password on my Netgear WNDR3700v4 router.
Can I do that on the router interface page, or is that done elsewhere?
Thanks!
Message 1 of 5
Accepted Solutions
Spica
Re: How do I change the GUI password on my WNDR3700v4 router?
Thanks for your help. It worked! So we can't change the user name - I see. That was my next question, which you anticipated. Thanks again!
Message 4 of 5
All Replies
Guru
here's the manual. Page 77 walks you though how to change the admin password.
http://www.downloads.netgear.com/files/GDC/WNDR3700V4/WNDR3700v4_UM_30Oct2015.pdf
Hopefully this works for you!
Message 2 of 5
Remember, you can change the password but not the username.
Message 3 of 5
Spica
Message 4 of 5
It is a common request. Didn't want you to waste your time trying to fix it.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1202 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
