- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is Nighthawk 7400v2 still supported?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings!
I go to this page, https://www.netgear.com/about/eos/, and see that R6400 is on the list of EOL/EOS. However, seeing "others" on the list, they explicitly say "Version 1" or "Version 2" when listed.
So I was wondering if the R6400 on the list is for the "Version 1" or when there is no explicit mention of version, does it mean the whole R6400 series is EOL/EOS?
Thank you for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is Nighthawk 7400v2 still supported?
Generally, references to model numbers if there is no V# that applies to V1.
Any reason for asking?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@peggy-peggy wrote:
My geek friend wanted to make sure I was using a router that was still supported since I have R6400v2.
That is a relatively recent variant (2022), but it is based on a 2015 original. It was never the most capable box on the shelf. But if it fits your needs, fine.
But your subject now says "7400v2". There is no R7400v2 that I can find. Just the R7400 from 2019.
Not sure what he expects of "still supported". By now the only changes for that router are likely to be on the security front. Unless you are paranoid, that it hardly likely to be a matter of life and death.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not paranoid per SE but I tend to use my devices until it becomes unsupported. My non-geek understanding is that unsupported stops getting updates, usually of any kind, this I've been always trying to budget for something newer in the future when that happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even devices that are "EOS" can received security updates. It has happened.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is Nighthawk 6400v2 still supported?
