× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear N600 WNDR3400v3
Dane_B
I want to use a WNDR3400v3 as Repeater for an existend Arris_Kabel-TV_Modem_Wlan-Router.
I need the Wlan Signal at the Place where the Arris is placed, also I need the Wlan Signal where the WNDR3400v3 is placed, and this in the same Network.
Can anybody help me?
Thanks
P.s.: I hope you understand what i mean (my english is not the best...)
Message 1 of 6
Accepted Solutions
Dane_B
Re: Netgear N600 WNDR3400v3
I do have a Cable between AP and router.
I tried vor some hours, but if I set AP-Mode on WNDR3400v3 its just the W-Lan working and not the ports for the fix cabeld stuff.
so I put the DHCP on again, I set the W-Lan settings at the same as they are on the Router.
and now it is all working in one network.
Thanks for all your help.
Message 5 of 6
All Replies
Retired_Member
Not applicable
Repeater mode doesn't seem to be available on this router. If it was I would think that option would be listed in the manual.
Message 2 of 6
Dane_B
Ok so the guy in the shop, sold me the wrong thing...
do you know an produkt i could use?
Message 3 of 6
Retired_Member
Not applicable
Assuming you what to improve/add WIFI coverage?  How would you connect to main router? If you have Catxx cable you could use almost any router in AP Mode or as a AP But, this requires a cable connection between AP and router.
Message 4 of 6
Dane_B
Message 5 of 6
Dane_B
I forgot to wrote two points:
i set an fix IP-Adress at the Arris Router.
on the WNDR3400v3 I had to set the AP-Mode off.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3272 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
