× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Power Led blinking red DGND3700v2
arfanvilla
Follower
Hi all
My netgear router (DGND3700v2) power light keeps blinking red.
No other LEDs are lit. So I get no connection to the router at all. I've tried to factory reset, but nothing happens, power LED keeps blinking red.
If the firmware is corrupt, how do I update with no wireless connection to the router?
Any help?
Thanks
Model: DGND3700v2|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 4
antinode
Guru
Re: Netgear Power Led blinking red DGND3700v2
> [...] power LED keeps blinking red.
   If you have a flashing power indicator, then you may be a candidate
for the TFTP recovery scheme.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] how do I update with no wireless connection to the router?
   Uh, use a computer with a _wired_ (Ethernet) connection to the
router?
Message 2 of 4
The DGND3700v2 is an ageing (2013 with its origins in 2011) ADSL2+ modem router.
Maybe it is just dying of old age.
Message 3 of 4
wcalifas
Prodigy
Did you try a different power adapter? could be the power adapter has gone bad.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2057 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
