× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
Old Router - Wired 400 mbps - WiFi 40 mbps no idea what I’m doing
Roundlikepi
Tutor
Hi! My wired net is 400 mbps, my WiFi turns it into 40 mbps. I’ve googled stuff on how to fix it but I honestly have no idea what I’m doing. Does anyone have any suggestions or can point me in a direction that isn’t spending money on buying a new router?
Thanks!!
Message 1 of 5
Accepted Solutions
Guru
Re: Old Router - Wired 400 mbps - WiFi 40 mbps no idea what I’m doing
A couple things.
1. the WNR2000 isn't gigabit capable. It only has fast ethernet (10/100mbps). Its a very base model N300 device.
2. 2.4ghz is a slow network. hitting 40mbps on it is about what you can expect from that band on that router.
3. If you have 400mbps, I'd look at upgrading your router. Your router right now is the bottleneck in your system.
You have an older, slow, n300 router without much capability. If you're paying for 400mbps, its time to upgrade to a dual band, gigabit device. I'd look at some of the newer AX routers with that speed capability.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 5
All Replies
Guru
what actual router do you currently have?
Are you testing on 2.4ghz or 5ghz?
what device are you using to test on? (model)
Message 2 of 5
Roundlikepi
Tutor
This information probably would have helped.
WNR2000v5 - gosh I hope this is the model
I have no idea how to tell what im testing but I think someone once said something like 2.4.
I’ve speed tested on my HP desktop, laptop, Dell work laptop, and my iPhone 7.
Message 3 of 5
Guru
A couple things.
Message 4 of 5
Roundlikepi
Tutor
Thank you so much for explaining this. I really appreciate your help!
Message 5 of 5
Discussion stats
  • 4 replies
  • 856 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
