× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Port Forwarding Issues
muffintop
Follower
I am trying to run a Minecraft server off my PC, but Ive found Port Forwarding to be a pain, (I check if my port is open or not here) Ive set up a static ip, and am sure my ip is correct.
I'm not sure what the issue is, if its worth anything, the router I'm connected to is connected to an Xfinity modem, I found elsewhere that it might help to port forward my router on the Xfinity website, but the router isnt even showing up in connected devices.
Help would be appreciated.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
Guru
Re: Port Forwarding Issues
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Please give brand and model# of the ISP modem there as well.
Thank you
Message 2 of 3
Rather than heading off on a wild goose chase that will only slow down your quest – this is as as good a place as any for your question – did you try this?
Search - NETGEAR Communities – Minecraft server
Looks promising.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1072 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
