- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6200v2 Guest passphrases don't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: V1.0.1.14_1.0.14
A variety of devices can't connect -- but they see the guest access SSIDs just fine.
Access to non-guest SSIDs works great, with security and passphrases on.
Access to guest SSIDs works when security is set to "none"
Choosing any of the WPA/PSK settings causes the client devices to try, fail, and report "could not connect to network" for the Guest SSIDs.
Changing the passphrases doesn't help.
Allow guests to see each other is Off.
Router has been reset, and I've retried.
Same for 2.5 and 5Ghz bands.
Are there any known issues around this? (e.g. Settings don't change on hitting "apply", or text passphrases are interpreted as hex in some combination of events, or guest SSIDs that have the same first N characters as the non-guest SSID fail, or...?)
Any other suggestions are welcome!
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Obi-Quiet,
Thank you for responding.
I personally have not encountered any posts/thread this issue with this specific model. Checking the release notes for the different firmware versions also do not indicate any fix for this specific issue. However, this is a step that you can try for isolation. You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6200v2 Guest passphrases don't work
Hi @Obi-Quiet,
1. Try updating the router to the latest firmware version (1.0.3.10) then do a factory reset.
2. Does the issue persist when using the default settings of the Guest Network?
3. Are all the wireless devices affected?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Obi-Quiet,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the responses!
Yes, all devices that I have tried to use with the guest network have this problem. I will generally have guests try the guest network, then revert to removing it's security just to get them connected.
I have not made any changes since I posted.
Before I go to the trouble and time of updating firmware and a factory reset (and the associated reconfiguration) can you tell me:
a. Has anyone reported this before? If so, what was the solution? (e.g. which firmware version fixed it, or whatever the fix was)
b. Is there any indication that a firmware between my current one and the most recent one corrects this problem?
It's basic enough I have to think someone else has run into it, and you will find it in your support database or internal release notes.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Obi-Quiet,
Dexter
Community Team
