× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6250 Wireless Bridge
2321kamykom
Can I bridge a NETGEAR R6250-100NAS Router to a NETGEAR R6250-200NAS Router?
Model: R6250|Smart WiFi Router (AC1600)
Message 1 of 4
Accepted Solutions
Guru
Re: R6250 Wireless Bridge
I
@2321kamykom wrote:
I am trying to do this: https://kb.netgear.com/20831/How-to-set-up-Bridge-mode-on-R6300-R6250-R6200.
Thus, can I set up "Bridge Mode" between a NETGEAR R6250-100NAS Router and a NETGEAR R6250-200NAS Router? They're the same model but different versions.
Thanks
If you look at the sidebar on the right side that shows what devices it applies to, it shows the article applies to the R6250 and R6250v2.  It'd be worth trying. Worst case scenario is just resetting them.    the manual @antinode refers to would be beneficial too 🙂
Message 4 of 4
All Replies
antinode
Guru
> Can I bridge a NETGEAR R6250-100NAS Router [...]
   "R6250[v1]".
> [...] to a NETGEAR R6250-200NAS Router?
   "R6250v2".
   That depends on what "bridge this to that" means to you.  It might
help if you explained exactly what you're trying to do, in plain
language (without using ambiguous terms like "bridge").
   Possibly useful: Visit http://netgear.com/support , put in your model
number(s), and look for Documentation.  Get the User Manual(s).  Look
for "access point".
Message 2 of 4
2321kamykom
Thanks
Model: C6250|AC1600 WiFi Cable Modem Router
Message 3 of 4
Guru
I
Thanks
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1970 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
