× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6300v2 - Can I restore settings after firmware update?
StarkmanAlive
Greetings all,
I'll be doing a firmware update to our R6300, and I've already made a backup of the settings (which only contains simple stuff like security settings and password stuff). After the update, can I restore the configuration and not mess anything up? I know that sometimes there's advice given to not restore the settings because it can undo what you're trying to do via a firmware update.
Thanks.
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: R6300v2 - Can I restore settings after firmware update?
> [...] my router was issued by my cable company, and it doesn't allow
> updates (they said they do auto updates, but who knows).
   What's your "my cable company"?  What's the actual firmware version?
If it has a "CH" suffix (or similar), then that would be consistent with
ISP-specific firmware ("CH" for Charter).
   There have been efforts to replace such ISP-specific firmware.  See,
for example:
      https://community.netgear.com/t5/x/x/m-p/1543374
   But, if you're still using that ISP, then replacing the firmware
behind their backs could be unwise.  If you just bought a used R6300v2
for general use, then using generic firmware might make more sense.
Message 4 of 5
All Replies
antinode
Guru
> [...] After the update, can I restore the configuration and not mess
> anything up? [...]
   First, you shouldn't need to restore anything.  The old settings
should survive the firmware update.
   Second, it's Netgear router firmware, so almost anything could
happen.
> [...] I know that sometimes there's advice given to not restore the
> update.
   What you're probably (mis)remembering is advice not to restore old
settings after a settings reset (not a firmware update).  If settings
become corrupt (and that causes bad behavior), then a settings reset
might solve that problem.  Restoring the corrupt saved settings could
undo the benefits of the settings reset.
   Firmware and settings are different things.
Message 2 of 5
StarkmanAlive
Thanks for the input. I had forgotten to mention that the instructions say to do a factory rest (thus wiping out my settings) after installing the firmware update. Additionally, I can't do a update anyway, so I've found out; my router was issued by my cable company, and it doesn't allow updates (they said they do auto updates, but who knows).
We'll thanks again.
Message 3 of 5
antinode
Guru
for example:
Message 4 of 5
StarkmanAlive
Yeah, it's charter, and yeah, it has the CH suffix. So, I'll be leaving it alone.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1835 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
